Will 14.9-38 fit on 16 wheels
Lee
02-09-2003 18:02:58
will they fit or should I keep looking for some 15.5 for my farmall H.
joe
02-10-2003 16:21:28
 Re: will 14.9-38 fit on 16 wheels in reply to Lee, 02-09-2003 18:02:58
yes they will fit. they make the tires look bigger than they are. use bigger tubes and fill them with the valve stem in. I learned the hard way. filled them with the valve stem out and a lot of air with the right size tube and blew the tube patch it and did it again and again
steve
02-09-2003 18:20:18
You can push it out there with the tube but you will have to increase your air pressure to get the center of the tire on the ground.If its on a pulling tractor you may create a bouncing problem.Or I may be completely wrong and they may sit nice and flat at 14 LB. I would think there has to be someone on here who has done it!! Just my two cents worth if its worth that.
WILDMAN
02-11-2003 04:42:15
 Re: Re: will 14.9-38 fit on 16 wheels in reply to steve, 02-09-2003 18:20:18
I RUN 16/9S ON 18"ALUM. RIM TUBELESS.
