Stock MM U weight 5350? huh?
Mopower
02-07-2003 06:15:11
I have an 1948 MM U that I pull. It has NO features on it like hydraulics, belt pulley or shaft, headlights, etc. It DOES have a PTO and cast centers on the rear wheels which will stay that way. I never slimmed this machine up, but it weighs about 5,350 lbs. Does this sound right? I was told some of the U tranny castings were lighter. I am not sure why this machine is so light. I have seen other Us at about 5700 or so with similar equipment. Not complaining one bit. I have a 403 power unit. Will this bigger engine add much weight with taller blocks and crank, etc.?
Brian F. Williams
02-08-2003 18:36:27
 Re: stock MM U weight 5350? huh? in reply to Mopower, 02-07-2003 06:15:11
I have a '47 UTU that weights about 5400. Just like yours except with a belt pulley.
YES
02-08-2003 15:05:55
YES it will...
