JD70 Flywheel Walks
ToddF
02-06-2003 14:37:10
I was out pushing snow with my Jd70 gas last night when I developed a tick. Well after some poking around I've determined that the flywheel has walked towards the end of the crank shaft and opened up the thrust clearance enough that something internal has started to touch where it shouldn't! My question is what does the tin nut do that looks like it might hold the flywheel on? LOL. What is the trick to keeping the flywheel bolts from loosening? Should I use some thread locker on them, or have I just not tightened them enough? The splines look good and there isn't any noise from a loose flywheel. The only sign of looseness is that it has walked. It has been bored and stroked and is capable of putting out a fair amount of Hp above stock. Have any of you had trouble keeping the flywheels on these things as a result? I'd like to know what any of you have experienced.....ToddF.
PeteNY
02-09-2003 06:38:31
 Re: JD70 Flywheel Walks in reply to ToddF, 02-06-2003 14:37:10
Todd, Ours loosened up very quickly, tightened her, and this really didn't work, found that the splines had opened a little. We had a pull that weekend and didn't want to have her down long enough to wait for Dengler's to ship us a taper lock, we used some green loc tite on both the splines and the bolts, figuring we would replace it this winter...still tighter'n a new brides suitcase! Pete
Eric
02-07-2003 05:12:11
Stock 70's have the same problems with the flywheels. Go get some grade 8 fine thread bolts. You can tighen them more than a coarse thread. If you have run it loose long enough to hurt the splines, then start looking into a taper-lock. Also start a regular maintenance routine to check the crank end play to see if it is moving. As for tighening, I use a 6 foot extension and give it all I can.
G Taylor
02-07-2003 08:14:34
 Re: Re: JD70 Flywheel Walks in reply to Eric, 02-07-2003 05:12:11
Using a torque wrench on dry clean 3/4" grade eight corse thread bolts with hardened washers is 375 ft lbs. Any more and the clamping force drops instead of increasing.
Jim F.
02-07-2003 07:01:45
Carefull with the grade 8 fine thread bolts!!! It is very easy to bust the flywheel with them. With the fine thread you do not realize how much more pressure you are putting on the cast flywheel!!! POP... been there done that.
Eric
02-07-2003 09:53:41
 Re: Re: Re: JD70 Flywheel Walks in reply to Jim F., 02-07-2003 07:01:45
I'll keep that in mind Jim. But, this has worked for me on a 70 gas and a 730 diesel with no breakage or movement. Maybe I'm just lucky.
Bill V
02-06-2003 15:22:53
I have a friend that has had that same problem with a 70 that has been bored and stroked. He ended up putting a taper lock flywheel on his to keep it from coming loose, however he does use his on the farm regularly. Loctite will definitly help and try to get the bolts as tight as possible.
a puller
02-06-2003 16:56:16
 Re: Re: JD70 Flywheel Walks in reply to Bill V, 02-06-2003 15:22:53
if u drill a hole in the end of the crank, u can make a plate with a recession to keep it on. Just don't break off the tap.
A puller
