PETRON PLUS engine treatment??
IH Man
02-05-2003 15:43:46
Any of you Pullers ever use Petron Plus Formula 7 engine treatment in any of your tractors or trucks??
I have seen some impressive demonstrations on a electric motor driven bearing friction machine on how it reduces friction. Any feedback appreciated..... .
buckmaster700
02-07-2003 16:05:37
 Re: PETRON PLUS engine treatment?? in reply to IH Man, 02-05-2003 15:43:46
its good stuff but dont put it in a fresh motor the rings wont seat to save there butt run it a fue pulls first
Ron
02-06-2003 06:08:44
I have had very good results from applying Dupont Teflon to the ( New ) cylinder walls, and then heating the block in an oven, to bake it in..... Having the piston tops Annodized will help reduce heat absorption a LOT...there-by increasing the BMEP...Ceramic coatings on the combustion chambers will help the same way.... There is NO end to the things you can do, to make power....!!!! I have never seen any "pour-in" stuff that helped as much as the Baked-in Teflon.....!!!
