Measurements of pulling force?
Charlie
02-05-2003 05:14:58
Of necessity, I've always been interested pulling stumps with undersized equipment. Would like to get more scientific about it. Does anyone know of any reference sources on the pulling power of dozers, bobcats, tractors, and normal pick-up trucks? Also measurements of pulling power on crowd of backhoe, to compare with calcuated values. "Moving the Earth" (a great reference book) has some limited data, but I'd like to find a range for various machines. Thanks.
phil
02-05-2003 08:36:25
 Re: Measurements of pulling force? in reply to Charlie, 02-05-2003 05:14:58
Lots of variables - pulling surface, dirt, blacktop, grass - makes it tough to standardize. I went to an antique tractor pull that used a load cell in the pull chain to the load sled. The load cell reading was divided by the actual weight of the tractor. Those 2 parameters (weight & chain tension) correlated well. The results (about 200 pulls) indicate that 100% is a good expectation. About 10% of the pulls went into 3 digits, 115% & 112% were the highs. To get 100%, the tractor needed to be balanced to get all of the weight on the rear & it had to be in a low enough gear to avoid powering out. For example, if 25% of the weight was still on the front wheels when the tractor spun out, the score would be about 75% (which, coincidently, is 100% of the weight that was on the drivers). But if the front tires lifted slightly at spin out, then all of the weight was on the drivers (plus some down-force from the chain) & the result might be 105%. For stump pulling, where you are always in first gear & you can usually put all of the weight on the drivers (this is for sure with a 4WD), expect to pull 100% of the vehicle weight.
