Minn. Moline head advantage
Mopower
02-04-2003 08:33:19
I would like to hear pros, cons, and comments regarding Minneapolis Moline round port heads vs. the square port heads. Such as 10A4210 vs. 10A4230 or similar types. Square port heads are better, but can round porters be built well? I am debating whether to hold back, or go all the way with nicer heads. Interested in hearing what people have done and what they think.
Ethan
Andy
02-04-2003 21:39:56
 Re: Minn. Moline head advantage in reply to Mopower, 02-04-2003 08:33:19
I have talked to a few people who run them on U's and the general concesious is there isn't much noticeable difference at or near stock rpms,(when comparing to a similar compression round port head). I am going to try them because I have a set sitting on a shelf. I will post the difference when I dyno(might be a while).
dave
02-04-2003 15:56:35
good ? were doing same thing on ub.we got 4210 heads and are probable going to stay with them. we will run the big manifold[300 cfm's]and do some porting. if i can find some 4230's or 31 cheap i might change mind. no expert here just going on other peoples advise. hope more answer your ?.
Andy
02-05-2003 08:05:47
 Re: Re: Minn. Moline head advantage in reply to dave, 02-04-2003 15:56:35
Dave, you may want to talk to someone who has ported these before or find a diagram of a cross section so you don't grind through. I saw a guy who cut a cracked one into quarters, thought that was a good idea. I have seen some ported 4210's that have huge ports. I did a set of 4213's but kept it pretty tame (about .100 bigger on the intake and polished under the valves.
Dieselbear
02-04-2003 16:49:47
The square port heads will flow alot more air than the rounds will.
Ethan
02-05-2003 04:11:21
 Re: Re: Re: Minn. Moline head advantage in reply to Dieselbear, 02-04-2003 16:49:47
Dex Holshouser e-mailed me to tell me that you have one tough GBD. I am considering buying one and I was curious what experience you have had with it. You can e-mail me if you like at [email protected]. I sure would appreciate some info on the MM diesel system. Thanks!
