Oliver 66 clutch
Erik H
02-01-2003 07:56:23
My Oliver 66 has an 8" clutch, and I'm incresing the HP a bit over stock- is it recommended that I find a way to go to 9"? What brand/style is a good heavy clutch for pulling?
dean
02-04-2003 18:24:30
 Re: Oliver 66 clutch in reply to Erik H, 02-01-2003 07:56:23
shouldnt need a button clutch if under 50hp..they are very jerky on start off as the matl gets hot it grabs and doesnt slip..nature of the beast... 5th gear is correct unique is fabulous at building clutches to suit your needs will set up whatever spring pressure you need on pressure plate and probably could go with full face metallic lining on disc to have less "chatter" and still hold for you..# is 636-488-5242
fifthgeardeere
02-04-2003 10:41:03
Send your clutch assembly and flywheel to Unique Automotive in Jonesburg, MO. They will give you a "button clutch" that will hold a lot of HP. They've done good work for me at fair pricing.
