Will my 60 make it to 5500 with 18.4X34's?
John
01-29-2003 14:30:29
If so how much striping would I have to do? Would it even be worth it?
Mike Aylward
01-30-2003 14:37:55
 Re: Will my 60 make it to 5500 with 18.4X34's? in reply to John, 01-29-2003 14:30:29
John, it can be done but you will run out of balance weight. I have pulled a 60 for several years and with about everything stripped that can be taken off the tractor with me on it will weigh about 5300 with 15.5-38's on it. I can run 16.9-38's and will add about 150 lbs. The trouble with most 34" rims is they are made out of heavier material than most of the older 38" rims. A light set of 18.4 38's on a light set of rims will often weigh no more and sometimes less than an equivalent 34". I machine cut tires on a custom basis and have scales that I can weigh wheel and tire combinations and this has been my experience. Hope this helps. Mike
Ethan
01-30-2003 04:35:11
Do you have 18.4x34s yet? What are you planning? Cut tires or not? I have some 18.4x34 Firestone Deep Treads that are a perfect canidate for cutting. How does your JD60 pull? I am used to seeing 70s and things. Always been curious on that new of a Deere machine. I like them. Just curious.
John B.
01-30-2003 01:47:31
Should be able to easly. We ran them on our G at that weight with pressed steel rims.
not worth it
01-29-2003 16:22:02
just pull 6000 and up not worth all the effort and $$$
