Wider rims
john
07-02-2001 06:09:22
I see a lot of 18.4x34 tires on rims that have 2or 3 inches added to them. How much dos'e that help traction?
al
07-04-2001 08:40:44
 Re: wider rims in reply to john, 07-02-2001 06:09:22
In my area the pro's are going back to the manuf. stated tire size for rim. 18-4-38 on a 16 rim
etc...
DP
07-03-2001 19:02:56
I run 18.4-38's on 18 inch rims on the old G. The face of the tire lays out flat, and with the 8 ply tires, I run around 6# pressure. Digs out a real flat hole.
Mike
07-06-2001 17:21:20
 Re: Re: wider rims in reply to DP, 07-03-2001 19:02:56
I run a G w/ 20.8 34 's on 22inch wide rims- same results- more footprint on the ground
Greg H
07-02-2001 10:01:56
If you don't keep your tire pressure up it's actually a detroment. without adequate tire pressure your centers will be more prone to curving in, and you will only be pulling or spinning more likely with the outside edges of your tire towards the end of your pull. If you do it right and don't get carried away, you can ge a wider cleat on the ground. Later, Greg H.
