Farmall M
Joe
01-28-2003 08:13:11
I'm trying to keep weight down on the "M".
If I leave the swinging drawbar off and just use the "U" hitch which is attached to the axels.
It would be lighter and the hook would be closer
to the axels. Is this a bad idea?
SH puller
01-28-2003 20:02:48
 Re: Farmall M in reply to Joe, 01-28-2003 08:13:11
We pull from u hitch - if front raises a little the hitch wont lower as much . takes some getting used to when changing from swinging drawbar asbalancing needs change. Good luck !
Farmall Daddy
01-28-2003 17:34:56
I pull a '49 M and it weighed 5420 with me on the seat. Since then, I have bored it, and left the hydrolic pump out. The pump itself weighs 50-60 LBS. at most. I run 1 set of wheel weights on the rear and no suitcase or any other weights. I also pull for the drawbar, not the belly tongue. The solid steel bar that I pull from can hold at least 100 H.P. because 450's have the same drawbar. I would leave the tongue off and just pull from the standard bar. Hope that gives you an idea on what you can do.
IH Man
01-28-2003 08:24:14
If you plan on Pull'n in Farm Stock class, some organizations require that the stock draw bar be attached to tractor belly where the pull clevis is attached. They will not allow "horseshoe" radius bar as a hook location..... ...
A stock "M" without any weights should weigh in at about 5450 lbs....ideal for 5500 lb class.
