Wc build up
rk
01-27-2003 13:45:58
I have a 1939 wc with the stock block and i was going to put a d17 kit crank and pistons, now i want to use lp pistons is my wc block going to take it, if so how much hp can i expect. thanks
Farmall Daddy
01-29-2003 15:46:21
 Re: wc build up in reply to rk, 01-27-2003 13:45:58
I checked on an E3 motor, it is a D-17 motor and they want $1000 for it. If you oversize it to 4 1/8, you get 45-49 horsepower, with a WD-45 manifold. You can not fit a WD-45 crankshaft in the WC block because of the 1.5 inch longer stroke. You would have to grind it down. I checked on the piston kit and they are $450 cheaper than the combine motor. I'm putting in bigger pistons so I don't have to put so much money into a motor that may need an overhaul. Just my two cents.
oldtimer
01-29-2003 19:51:16
 Re: Re: wc build up in reply to Farmall Daddy, 01-29-2003 15:46:21
wd45 crank is 4.5in stroke wc crank is 4.0 stroke that's half inch longer stroke,quarter inch on top,quarter inch on bottom, drop it in and go works fine. ot
Andy
01-29-2003 16:55:42
I have a WD-45 crank in my WC and I did not have to do anything at all to make it work, just put it in and go. It is a 1945 year model
Farmall Daddy
01-27-2003 13:50:19
I am going to oversize my styled WC as well. I went to the Allis Chalmers catagory and within 10 minutes I knew I could fit 4 1/8 in it pretty easy. I am goind to use the gas piston. If you can find a D-17 LP head, that will jump the compression and get you more horsepower as well.
oldtimer
01-29-2003 20:02:48
 Re: Re: wc build up in reply to Farmall Daddy, 01-27-2003 13:50:19
how can a lp head be higher comp than a regular head? My wc's and wd's are flat can't get any more than that. Higher comp,longer stroke,(wd45 crank, 4.5 stroke).quarter inch closer to the top,quarter in lower at the bottom ot
Don Karpel
01-27-2003 14:18:36
First off a D-17 crank will not fit in a wc block. The mains are a different size. Go with a WD-45 crank that will give you 4.5 stroke to start with. I have componets that will give you 425 cu in motor if interested.
conley
06-11-2006 18:17:38
 Re: Re: Re: wc build up in reply to Don Karpel, 01-27-2003 14:18:36
i would like to talk to you about building a wc
stroker. thank conley
Allis Puller
01-27-2003 14:57:25
Don is correct about the journals on the D-17 are .100 smaller. But a WD45 crank will do you the same. If it were me I would not put that money into a WC block. They were noted for splitting down the middle, unless you wanted to get it pinned. I think you'd be farther ahead to just go find yourself a Gleanor E combine and you'd have a 55 h.p. motor give or take. I've bought two of them, one I bought the whole combine for $300.00 and the other I got just the motor for $100.00. They were a much stronger block, "they weigh like 60 lbs more" and they got the big carb,intake, and better govenor. I'd rather see you build on a motor like that. Just my thoughts.
rk
01-27-2003 15:37:18
 Re: Re: Re: Re: wc build up in reply to Allis Puller, 01-27-2003 14:57:25
Thank guys for the advise it is really helping me out
rk
01-27-2003 14:50:30
yes i would be interested i will email you Don
