Massy for a canidate
V-8 builder
01-23-2003 19:37:42
what is a good massy Harris to put a 455 wildcat buick engine in....will a 22 be strong enough to hold the power or maybe a 30 or 33? I have a chance to buy each of the mentioned models I would like so input.
yep
01-25-2003 14:23:05
 Re: massy for a canidate in reply to V-8 builder, 01-23-2003 19:37:42
30/33/44 same thing, wheelbase, same
Jake
01-24-2003 18:47:52
I would NOT recomend the 22 because I don't think it will take the abuse. However, if you look at a lot of the original NTPA modified tractors, most had either Massey 44, 55 or Cockshutt rear ends... If you have to use the stock tub where you pull, I would think that the 30 or 33 wheel base would be too short as well.
u2
01-24-2003 05:54:43
22 no 30 ?? 33 and 44 the same rear end
