Farmall H bore
Lee
01-23-2003 16:32:20
Can any one tell me the largest bore you can have and still use sleeves. On farmall board they sayed you cant bore walls are to thin.
Wheelie R
01-24-2003 22:10:01
 Re: Farmall H bore in reply to Lee, 01-23-2003 16:32:20
Try the V-8 head set-up; it allows for a 5 in. bore. Combine that with the recast blocks and you've got 500 inches.
hpuller
01-24-2003 19:32:24
I have a H with a H block and I boarded it out to use 350 pistons with sleeves. It will make about 40-45hp with stock stroke and a domed piston. Hope this helps.
H
01-24-2003 18:28:05
Pull the sleeves and put 460 pistons in have run 3 years that way.
Mike S
01-24-2003 12:38:20
I had a H block bored to the counter bore (where the top of sleeve sits) and the cylinder wall was a little thin but the guy at the machine shop said it could be ran this way if I filled the block half way with hard block filler. This was a cracked block I was checking how far we could bore it for a pulling engine(no sleeves). Im sure you could run Farmall 350 sleeves in your H block if you have a good machine shop to bore it.
DOUG
01-24-2003 04:46:14
I RUN 4 "60 OVER
Tony630
01-23-2003 17:08:11
Well, First off we need to know what block you have in your tractor. Do you have an original or have you gotten brave and installed a 300-350 block?
Answers:
H - 3 3/8" to 3 7/16"
Super H - 3 1/2"
300 - 3 9/16" to 3 5/8"
350 - 3 5/8"
All are the factory specs on the sleeves and piston kits you can order from any engine sleeve aassembly supplier.
Now, after that you can bore the block on any of the above engines, but only so much. And on top of that you need a good machine shop that you can trust not to make a mistake and bore it wrong.
Tony630
Lee
01-23-2003 17:32:15
 Re: Re: Farmall H bore in reply to Tony630, 01-23-2003 17:08:11
I have an H block
Lee
01-23-2003 17:28:06
I have an H block
