Super 77 sleeves 3 3/4 bore
oliverman
01-20-2003 18:47:50
would the super 77 overbore 3 3/4 work in a non-super 77 block without machine work
oliverman
01-21-2003 20:34:20
 Re: super 77 sleeves 3 3/4 bore in reply to oliverman, 01-20-2003 18:47:50
thanks for the reply's
Jeff
01-21-2003 03:02:12
Should. I was told that when the Supers came out you could get the sleeves and pistons for your 77 and change them out, Something like a "Super Kit". From what I can research about all they did with the bore of the Super was use the sleeves and piston size of the All Fuel engines in the High Compression ones.
steve
01-21-2003 19:38:32
 Re: Re: super 77 sleeves 3 3/4 bore in reply to Jeff, 01-21-2003 03:02:12
Yes, the 3 3/4 sleeves and pistons will work in the fleetline, super series and 770 with no modifications.
