Tack for oliver
bgar
01-20-2003 15:52:46
i am looking at putting a tack on my oliver 88 pulling tractor wheres a good place to run the wires and where do they hook up????? ????? ????
Ray B
01-22-2003 16:40:38
 Re: tack for oliver in reply to bgar, 01-20-2003 15:52:46
iF YOU HAVE AN AFTERMARKET ELECTRIC TACH ONE WIRE WILL GO TO GROUND,ONE WIRE WILL GO TO BATTERY POWER,ONE WILL GO TO LIGHTS,AND MOST IMPORTANT ONE WILL GO TO THE [-]NEGATIVE SIDE OF THE IGITION COIL,THAT IS IT YOU HAVE A STOCK IGNITION SYSTEM.THE COLORS OF THE WIRES VARY FROM MANUFACTURER SO CHECK THAT OUT FIRST. RAY
