Lighten up H
FarmallKid
01-08-2003 11:17:57
can anyone suggest a few ways to make a 1944 Farmall H lighter i need to lose some weight to get in 3500 class tractor weighs about 3800 maybe a little more i am only 15 and really would like to get into the 3500 class as there are more kids in that class whereas in the 4500 clas its all veterans any ideas would help THANKS
hpuller.
01-08-2003 18:22:43
 Re: lighten up H in reply to FarmallKid, 01-08-2003 11:17:57
You can take the pto out of the tractor and make a plate to cover the hole. You can also drain a few gallons of oil out of the rearend. I assume you have removed the belly pump, belt pulley assembly, and air cleaner. You will have to go with a steal pressed wheel and hubs to make 3500. I had to use weld on axle plates for me to make 3500 but I weigh 250lb and it let me run one 75lb weight. If you have any questions email me I have built 2 h pullers.
Farmall Daddy
01-08-2003 16:42:29
I real good at figuring out how to loose weight on tractors. Instead of spending alot of money on nonsense, non original ideas/parts, strip down with what you got. Remove the hydro pump. Run with enough gas to get you by to pull. Remove the fenders. Remove the PTO shield. If you want, remove the entire air cleaner assembly, breather, etc. This will get you more power by not running without the air cleaner hose. If you have already done these, find spoked rear wheels. I have seen an H down in the 3500lb. without having to change the front end, and gas tank, which in my own opinion is stupid. The WC's {if any} are highly compettive in that class, because I pull one.
Farmall Boy
01-08-2003 14:20:20
HEY I'M ALSO 15 AND DON'T PULL AN H BUT AN M AND HAVE HEARD THESE ARE SOME OF THE THINGS YOU CAN DO. TO GET IT DOWN TO 3200# OR LESS..ALUM TRANS PLATE LIGHT WIEGHT FRONT END, ALUM WHEELS FRONT AND BACK WITH 16.9S, ALUM FRONT RACK , ALUM MOTOR MOUNTS ,FIBERGLASS GAS TANK. 2GAL ALUM TANK INSIDE,ALUM FENDERS. YOU CAN ALSO REPLACE TRANS COVER AND CUT SOME WIEGHT OFF FRONT BOLSTER .ALL THIS IS LIKE HORSEPOWER IT IS NOT CHEAP!
