Re: Buying a Tires for Pulling
Ethan Berry
01-08-2003 10:08:17
Troy,
I would have to say that Firestone Field and Roads have a great reputation and pull well, but Armstrong tire (now called Titan) are very good. They are similar to the Firestones, but they have a slightly curved lug that bites and holds on very very well. It bites in and pushes the dirt outward torwards the flatter part of the bar. I recomend either one. My old Armstrongs can't be beat. We will see what happens with more power this year. Too bad you can't cut because I have a set of Firestone Deep Treads in 18.4x34 (the ultimate tire) ready to sharpen up and pull. They are very stiff and dig like no other. Anyone interested they are $300 for the pair with tubes. See my ad on this website. I got pictures. But I would say try those Titan tires. They are very classy and clean looking, slightly cheaper, and pull real well! I have seen MM GB tractors really kick butt in the mid Michigan area.
Farmall Daddy
01-08-2003 16:24:49
 Re: Re: Buying a Tires for Pulling in reply to Ethan Berry, 01-08-2003 10:08:17
The best pulling tire that I have run into is what they call a Delta International Quality. I have a set of 13's on my WC and they don't give in at all or slip at all. They are the same tread stlye as the Firestones, but the have a thicker tread at a cheaper cost. Hope that helps you out!
Ethan
01-09-2003 04:19:20
 Re: Re: Re: Buying a Tires for Pulling in reply to Farmall Daddy, 01-08-2003 16:24:49
Neat! Where do you get them?
