JD
G Head ???
Rick
01-06-2003 13:14:46
I'm looking at a used cyclone head for my late styled G puller. The guy who has it says it has been shaved down quite a bit but he doesn't know how much. Could anyone out there give me a reference to determine aproximately how much this head has been shaved such as the stock thickness of head or distance from the block mating surface to the intake or exhaust valve? Also do the cyclone heads need to be pinned? If so at what compression ratio would pinning be required? Thanks in advance for your help!
richard
01-06-2003 16:42:33
 Re: JD - G Head ??? in reply to Rick, 01-06-2003 13:14:46
cumbustion chamber on stock cyclone head is 326cc. took .250 off it an cumbustion chamber had 180cc. later richard
Thanks!!!
01-06-2003 17:15:01
 Re: Re: JD - G Head ??? in reply to richard, 01-06-2003 16:42:33
Thanks for all your responses they are a big help!!!! Rick
Brandon
01-06-2003 16:36:36
A stock head is around 5 3/4" thick.
no pinning
01-06-2003 15:12:37
no pinning on a cyclone head. they've got enough meat to handle a ton of compression.
Jack
01-06-2003 14:59:21
I gained a little hp by shaving my G head.Mine was cut .250 thousanths and just started to flatten the eyebrows around the intake valves.
