More fuel for a 930 case Diesel
Willie
01-05-2003 19:43:01
This tractor has the in line Bosch german pump on it, right now, you can't really make this tractor put out any black smoke. can anybody tell me if I can turn more fuel to this tractor myself with the pump still on the tractor? If so how do I do it, and how much do I adjust without getting too much diesel? Thanks in advance! Willie
buckmaster700
01-06-2003 06:13:56
 Re: more fuel for a 930 case Diesel in reply to Willie, 01-05-2003 19:43:01
on the front of yur pump is a round cap w/2 flat sides its about the size of a 25cent remove it under it is a screw with washers on it remove screw and washers put in right hand and pitch over shoulder replace round cap #2 remove plate on rear of pump has 4, 10 mm bolts fuel will prob. run out no biggie there are 2 screws w/ jam nuts use the bottom one of the 2 loose the nut and screw the screw in DONT MESS WITH THE TOP ONE IT CAN RUN AWAY AND BOOM !!!! replace cover and refill pump with motor oil till it starts to run out the overflow tube i think mabe 12 oz will do
