MM U tall block
EDB
01-02-2003 11:01:34
I am using a tall block 403 motor in my U. Is there a significant torque or power difference using the tall blocks and rods compared to a 403 with M5 blocks?
Slo Mo
01-03-2003 16:35:08
 Re: MM U tall block in reply to EDB, 01-02-2003 11:01:34
Can't tell you about the torque, but it's getting harder and harder to find pulls around here that allow the tall blocks in a U. I am going to end up using short blocks in mine so that I can pull more. NATPA don't like them at all. Never mind some of the stuff that they do allow...
Don't make much sense, in order to be legal, I'll end up increasing the horsepower. Guess that some people don't like the fact that the MM makes cheap horsepower.
david
01-03-2003 15:11:14
tall block would be the way to go but check rules where you pull some don't allow tall blocks were building one have to go m5. hey shawn any reason you don't like welters kits just curious
Shawn
01-02-2003 20:55:26
Well it all depends on what pistons, rods and head you are running, but rod angle will make a diference also with the shorter blocks.
I would rather have the tall blocks over a welters special, if thats what your asking
Just my thought
Ethan Berry
01-09-2003 07:52:44
 Re: Re: MM U tall block in reply to Shawn, 01-02-2003 20:55:26
I think there would be better slow torque from the rod angle on the tall blocks. But I have engine theories and not tested many of them. Just observed others. Thanks for the advice.
