Compression ratio
John Deere Buil
12-31-2002 22:40:25
I would like to know everyones thoughts on compression. My oppionion is that about 8.5:1 is about right for low rpm's and low speed. I am pulling a John Deere A with about 8:1 copmression and am rasing it to about 9:1 and would like to know if this will allow it to lug down to about 500 rpm and still pull.
I would just like to know everyones thoughts
Brandon
01-01-2003 14:31:04
 Re: compression ratio in reply to John Deere Builder, 12-31-2002 22:40:25
How many pounds of compression does each cylinder have? Just curious.
Brandon
Ron
01-01-2003 08:28:45
9 to 1 is probably pushing it to the limit, if you plan to pull it down LOW...!! If you get pre-ignition, you will loose power, and hammer the bearings and rings to Death..!! Work on Breathing...Valve work, etc, so you can make Horse Power at a more normal RPM....otherwise, you are pulling it down to where it is breathing the best, and that is not where the BEST POWER is..... The ones who win, are strong at 800, or more RPM....
John Deere builder
01-01-2003 12:31:46
 Re: Re: compression ratio in reply to Ron, 01-01-2003 08:28:45
I do agree with you but in order to make it breathe right I am thinking I am going to have to raise the pressure in the cylinders. I have ported and ploished the head and manifold and have changed the rocker arm ratio to a little over 2:1 ratio. I am not to worried about pre-ignition becouse I am running high octane fuel (112 octane). I am not sure of how much air I can get into the engine with the stock air breather and I have to keep it original in appearince.
Pete
01-01-2003 17:50:20
 Re: Re: Re: compression ratio in reply to John Deere builder, 01-01-2003 12:31:46
Gut the inside of your old oil bath air cleaner. Modify it to accept a Donaldson style paper filter.
You might also consider opening up the runners on you intake manifold, but don't go too far on low rpm engines a long narrow manifold builds torque.
Pete.
JNDEERE
01-03-2003 05:00:01
 Re: Re: Re: Re: compression ratio in reply to Pete, 01-01-2003 17:50:20
Hey Pete,
Can you tell me what donaldson air filter you recommend to use after gutting the original oil bath unit?
R/ Eric
Tony630
01-01-2003 16:32:40
Just one small comment. Have you considered RPM'S. High compression needs RPM. 8.0 to 1 needs more than stock RPM'S to perform well. Compression hurts these motors as Ron said when you go past 8.0 to 1. The motor's just don't have the ability. Since you have changed your rocker arms changing the cam will probably over do it. Do check lift on all valves and make sure they're the same. If not may have cam wear. The CAM is a lot of that tractor when there is no stroke being added.
Post back if you've got any questions, I run a 630.
Tony
G Taylor....high rpm needs high compression
01-02-2003 10:35:37
 Re: Re: Re: Re: compression ratio in reply to Tony630 , 01-01-2003 16:32:40
High rpm engines with long duration cams require high mechcanical compression ratios. Power has to be extracted and the exhaust valve opens long before the piston nears bottom dead center. To get enough expansion ratio before the pistons drops and the valve lifts the compresison ratio must be raised.
01-02-2003 05:15:10
i runn 11:1 in mine with good results. it lugs great and very far down. the secret is to have head, manifold, and carb all matched up on flowbech. a stock head, manifold, and carb will flow a stock stroke motor just fine. i also have stock cam.
Ron
01-01-2003 17:48:10
Hey, Tony....how do you think an LP 630 would pull.??? Have you had to buy many parts for your 630.?? Where is a good place to get an original-looking steering wheel.?? Wiring harness.??? Thanks.!! Ron.
Tony630
01-03-2003 15:59:07
 Re: Re: Re: Re: Re: compression ratio in reply to Ron, 01-01-2003 17:48:10
Check your E-mail.
Tony630
Ron
01-01-2003 13:17:38
You can use Lighter oil in the air breather, or -- Non at all..!! Even remove the rire gause from it... Since you are getting serious about pulling..have you actually had the valves contoured, and re-shaped.?? You will get much improved air flow at .050" lift with the valve work..effectively increasing the valve duration, and maximum air flow at ALL lift heights... It involves making cuts on the back side of the valves, removing all unnecessary metal, contouring down to the actual valve seat cut, leaving only as much as you need for seat contact....Then polish them, to eliminate all evidence of the cuts..result...??? POWER..!!! Every engine I have done this on has been Fantastic....Well worth the effort...!!!! Be SURE to de-burr the entire combustion chamber, to keep pre-ignition down...Polish them, some if you can.. Black and Decker makes a rubber/abrasive wheel that works well, also port polishing kits have good abrasive wheels, too... Good luck..hope to hear more about how it goes..!!!!!
