Why no Standards?
The Inquisitor
06-24-2001 20:37:06
Would someone please explain why there are no standard tread tractors pulling? I'm more farmiliar with JD, but it applies to all brands. Yes there are 820's, W-9's, etc, but when there is a tractor that was built as a standard or row crop, the row crops are used as pullers (like a 70 JD and M & W-6 IH). It seems to me that since a standard came with wider tires, ususally the same overall height as a row crop, and the extra weight could be eliminated, it would make the best puller. Hopefully someone can shed some light on this. Thanks in advance.
Answer
06-25-2001 23:37:02
 Re: Why no Standards? in reply to The Inquisitor, 06-24-2001 20:37:06
There are two primary reasons row crops are the preferred tractor compared to standards. The row crop has a longer wheelbase. The row crop usually has a larger rear tire.
The combination of these two make the row crop a significant advantage over standards. Back to you burns
Rich
06-24-2001 21:04:29
I pull a oliver 88 standard,I do pretty well with it and have beat my brothers 88rc a few times.Up until this year I have been running 14-26 tires,Just put a set of 18.4-34 rears on it.Have to see what happens,Standards do require more effort to make them pull as good as a row crop,they seem to be little harder to balance and are not as easy to change wheel/tire combo Esp.when you have 8 bolt hubs instead of 9 bolt,that cuts down on rim options. Later Rich B (NY)
