Loseing weight on a M
Farmall Boy
12-29-2002 13:43:44
We have a 39 M that weighs 4740 with driver we were wonder how we could get it down to 4350 we have removed cast wheels, pulley, and belly pump.All comments are appreciated
super M
01-01-2003 08:11:03
 Re: Loseing weight on a M in reply to Farmall Boy, 12-29-2002 13:43:44
You should get ahold of Beaty performance in indiana. He has fuel tanks,alum rad., and alot of other stuff.He will help you
Rich
12-30-2002 10:08:28
Get a fiberglass tank too and an aliminum fuel cell.You'd be surprised how much that will take off besides the weld on hubs.Tomac has that too.
Brad--IN
12-29-2002 15:49:06
Switch the front bolster to a light weight steel one. Can lose a hundred there. Get rid of large cast hubs and use weld on plates. This will lose a hundred per side. Build all weight racks out of aluminum. Have done all of above to a '52 M and can run 4500# but have no extra weight. With your light rear tub and platform you should be able to have a couple hundred to spare.
Farmall Boy
12-29-2002 16:00:40
 Re: Re: Loseing weight on a M in reply to Brad--IN, 12-29-2002 15:49:06
where can u get a front bolster like that
Ind puller
12-30-2002 05:08:36
 Re: Re: Re: Loseing weight on a M in reply to Farmall Boy, 12-29-2002 16:00:40
Dennys has the light front ends.[Don,t forget to drain some of the fluid out of the rear end.]
supermpuller4
12-30-2002 09:29:23
 Re: Re: Re: Re: Loseing weight on a M in reply to Ind puller, 12-30-2002 05:08:36
Don't get one from Denny. Mine broke at the hub. I remade the bottom and got it going,another M that pulls with us had the same problem.
306M-PULLER
12-29-2002 18:20:46
I made my own.....i used 31/2" pipe with 1/4" walls and a 6"x6"x3/8" plate. i got spindles hubs, tires, and rims out of the Northern tool catalog. when i made it i cut a hole in the plate so i could weld the pipe on both sides. the pipe was 13" long. then i took the spindles and set the to the angle i wanted (no clue on a measure)then notched the end of the pipe so i could weld on 3 of the 4 sides of each spindle. I had a total of $210 in everything.
Jon
12-29-2002 14:43:37
We have a friend that pulls an M in the 4500 he has small front tires on alluminum wheels and 18.4X38 on alluminum. Tractor is totally stripped no weight brackets and no pto. He has to take the starter the out to make it to 4500.
ON A DIET
12-29-2002 15:53:08
 Re: Re: Loseing weight on a M in reply to Jon, 12-29-2002 14:43:37
Hey thats nothing! theres a puller in Michigah that has a "M" that weights 3500 and has weight bars and starter and weights on also,runs a nine speed too,runs 2nd ad 3rd high about 12mph,if you are serious about loosing weight,then maybe you should get ahold of him and ask what he did,maybe he will tell you.
Farmall Boy
12-29-2002 16:03:38
 Re: Re: Re: Loseing weight on a M in reply to ON A DIET, 12-29-2002 15:53:08
Well we have met who your probly talkin bout (Michael Tomac)but we don't want to go to that much of an extreme we jus want to go down a class.
deadeye
12-30-2002 04:24:32
 Re: Re: Re: Re: Loseing weight on a M in reply to Farmall Boy, 12-29-2002 16:03:38
If you want a lighter front end, I think there is one of the Massey front ends that is lighter and will fit an "M". Can't remember which one though. Maybe someone out of southern Iowa can tell you. I know there is a black 400 down there that has one on it.
deadeye
12-30-2002 04:24:24
