Rocker arms
Jd puller
12-16-2002 20:23:11
any one ever use them aluminum rocker arms from murphy's? are they any good? how are they changing the lift? Need some info.
redhead
12-17-2002 19:49:38
 Re: rocker arms in reply to Jd puller, 12-16-2002 20:23:11
Made 8hp on a JD-A that I pull against. I've give some very serious thought about a set for our M. Murphy's are real great guys to talk with on the phone. Good Luck.
G-MAN
12-17-2002 10:49:11
I don't have any experience with those rockers (they look pretty trick), but I can tell you how they increase valve lift. They do so by running an increased rocker-ratio, which is the ratio between the pushrod side of the rocker and the valve stem side of the rocker. The longer you make the rocker on the valve end, or the shorter you make the pushrod end, the higher the ratio goes and the further the valve will open. It's commonly done on performance automotive engines because it provides more valve lift and increased duration without swapping the cam. A common swap on a 350 Chevy would be from the stock 1.5:1 ratio rockers to 1.6:1 units. If they're equipped with roller tips, that reduces the tip scrubbing on the valve stem and some of the tendency for the valve stem to move sideways, which saves some wear and frees up a little horsepower to boot.
