88 diesel
bob wellner
12-15-2002 08:59:24
I am parting out A 88 diesel. would like to know if the block, cam, crank,flywheel, clutch, bell housing might interchange with A gas 88
A.P.
12-15-2002 13:53:35
 Re: 88 diesel in reply to bob wellner, 12-15-2002 08:59:24
Yes.
A.P.
cookie
12-16-2002 16:22:43
 Re: Re: 88 diesel in reply to A.P., 12-15-2002 13:53:35
Everything is interchangable with the gas motor except the flywheel and belt-housing Cant use the desiel starter on a gas tractor because the carb is in the way for the big starter. You need a different ring gear on your flywheel and the gas belt-housing and engine backing plate to match up with gas starter Bob
