Southern Nationals Rules Tunica Mean Green Pulling Team December 6th and 7th Farm Stock II Classes: Pre-1960 Tractors with stock engine No cut tires 18.4 x 38 MAX Hang on Weights-ok 10% over stock RPM Wheelie bars are mandatory 1st gear only, 4 mpg max 4MPH, 8 MPH Classes Pre-1960 tractors with internal engine mods Spacer Plates, girdles, power blocks 12 port head, 800 heads & jugs ok All parts must be of tractor origin 18.4 x 38 max tire, any cut, any rim width no duals Weights: 11" from center of rear axle to furthest point of front weights Rear weights must not stick out past tires on rear 20% over stock RPM Any gear, 4.0 MPH MAX 8.0 MPH MAX Draw bar 20"High, 18"back from rear axle Wheelie bars & breakaway switches mandatory No alcohol, no nitrous, no turbos, no blowers No Speed Limit Same as above Except 30% over stock RPM Speed limits start when any part of tractor passes the orange cone at 1/2 track. Tractors with side shields may be inspected. If a protest is made, it must be made before the end of the class. Protesters tractor will be examined first. Then and only then will the protested tractor be checked. Only a total of 3 pulls for 2 days This is the pull order for both days: Friday Saturday Farm stock II Modified Modified Modified Green sled White sled Green sled White Sled 4500 # 4 mph 6200 # No limit JD King of the Hill All other King of the Hill 5500 # 4 mph 7200 #No limit 3500 # 4 mph 6500 # 8 mph 6500 # 4 mph 7500 # 4mph 3500 # 8 mph 6500 # 4 mph 7500 #4 mph 7500 # 8 mph 4200 # No limit 5500 # No limit 10000 # 4 mph 4500 # 4 mph 5200 # No limit 4500 # 8 mph 5500 # 8 mph *Remember: This is a hobby for fun. It's not a political debate or event
