Wanting to build a allis-chalmers for 5500 thru 6500 lb. classes
tah
11-22-2002 17:14:21
would like to build a D-17 6 cylinder is it possible to make the diesel perform or does it need to be converted to gas if anyone has any information to help me would think you. planing on pulling div. 3 or 4 so yes I am planning on spending some money. just need to know were to start. thanks
KBMO
11-26-2002 12:17:35
 Re: wanting to build a allis-chalmers for 5500 thru 6500 lb. classes in reply to tah, 11-22-2002 17:14:21
You will be limited building it on diesel. They are not direct injection I don't believe. The 262 motor does not have a lot of room to add cubic inches either. However, with some work and money I think it could be made competitive in Division III. I know I would like to see one in the mix. A D-17 diesel would be something different. I have some more ideas if you are interested.
Irv
11-26-2002 11:30:55
A D-19 diesel is a D-17 diesel with a turbo. I would check with some salvage yards to see if could find a manifold and turbo in good shape off
a D-19. Then turn up your pump as far as you can!
You should be able to get 80+ horsepower. Good luck!
tah
11-26-2002 18:43:12
 Re: Re: wanting to build a allis-chalmers for 5500 thru 6500 lb. classes in reply to Irv, 11-26-2002 11:30:55
My brother and I are running a U moline now. pulling in 4 to 8 mph. classes I was raised on allis chalmer tractor and would love to build a bad D17 looks like the 262 would be a better choice for the build. You see some bad 226 in lighter classes but I dont think there is enough room to build a heavier class tractor to run with the molines & olivers. We are not allowed to run turbos but I think we can run diesel coverted to gas any ideas would help
hunter
11-27-2002 04:12:28
 Re: Re: Re: wanting to build a allis-chalmers for 5500 thru 6500 lb. classes in reply to tah, 11-26-2002 18:43:12
A 180 gas might fill the ticket - then
if turbos where allowed a 180 diesel
could be made to sing.
best,
bill koob
