U Mo engine
Fox
11-21-2002 13:58:23
New owner of a UB moline. Question: what are the current HP of these tractors? I would like to get 60-70 hp out of this. What are some of the parts and numbers people are swapping out to increase hp? I know nothing about these tractors yet.
Roadgear
11-22-2002 10:23:40
 Re: U Mo engine in reply to Fox, 11-21-2002 13:58:23
I pull a MM U and the first thing to do is bend over and buy a good set of heads. A set of 10A4232 heads in rebuildable shape will run ya $1000.00, but there well worth it. even on a stock motor they make HP. heads make or break a first place or a fifth place in the 4 cylinder MM tractors. I could sit here and list all day the parts needed to make one run good, but no matter if you have a kickass bottom end you aint got nothing till you got a good set of heads. another thing is to stay away from MM G's those built right will eat a U alive. good luck!!
Don't forget
11-22-2002 10:33:33
 Re: Re: U Mo engine in reply to Roadgear, 11-22-2002 10:23:40
The cam from a 670 will give you about 20% more horsepower than the stock U cam.
Jerry
11-23-2002 17:35:03
 Re: Re: Re: U Mo engine in reply to Don't forget, 11-22-2002 10:33:33
Motec Engineering will grind your existing cam and set your carb. up for you. A stock U has 54 horse power and a stock G puts out 75 horses.
docjoe
11-21-2002 19:34:02
call welters farm supply verona mo. ask for glenn they are mm experts. 417 498 6496. also if mm made it they have it. they are fair on their price. good luck with your mm. doc
