I need some high compression piston info please!
Fifty Three G
11-19-2002 06:24:34
I took the head off my 53 G John Deere down last night and it definatly has high compression pistons in it but what are they?These have the number 3 up top and 1026 at the bottom.I need to know what they are and how much over they are so I can get some rings.I appreciate any valuble info.Thanks,Jack(TN).
Todd
11-19-2002 21:16:34
 Re: I need some high compression piston info please! in reply to Fifty Three G, 11-19-2002 06:24:34
Jack if the piston is aluminum, all of the ones I have had has the bore size stamped of the face of the piston usually at the top (if its oversize). Do some more cleaning to see if you can find another number. I guess if you can't find anything else, they may be standard.
mark
11-19-2002 16:58:27
you will have to measure the cyl bore to get the right size
