Tractor Wheelie Bars
IHMan
11-17-2002 15:40:04
I am preparing to do some pulling with my IH "M" and wanted to build a set of Anti lift plate/bars. have seen some rules stating they should begin 3 1/2" from outside radius of rear wheel and be no higher than 10" from the level ground, also should be a 6" plate with no more than 20 degree tilt to the front? Is this pretty standard and accepted in most Pulling organizations? I am going to fabricate the bars from 2 3/8"sq. steel tubing and 1/4" skid plate.
Need some feedback from you experienced Pullers.Appreciate your response..... ....
baystatebinder
11-20-2002 17:17:38
 Re: Tractor Wheelie Bars in reply to IHMan, 11-17-2002 15:40:04
Go to Denny's you can't make them as good or as cheap as they do.
baystatebinder
11-20-2002 17:17:26
Fred
11-18-2002 04:16:21
Go to www.catpa.com ... Rules...Wheelie Bar Spec..
This is pretty standard specs I think
BUDD
11-18-2002 15:29:37
 Re: Re: Tractor Wheelie Bars in reply to Fred, 11-18-2002 04:16:21
Try this it mite work better. www.catpa.net
