Welding rear end on oliver 60
peter
11-16-2002 16:47:17
use this tractor for pullin justwondered if i could weld rear end for aposi unit ????? ?? peter
TimC
11-16-2002 21:37:02
 Re: welding rear end on oliver 60 in reply to peter, 11-16-2002 16:47:17
Can you tighten the spider gears by removing shims which should create a straight posi (will lock down the spider gears so they can't work) then you can put it back if you don't like it.
I don't know the drawbacks so try it at your own risk. This is just what i have heard.
