Oliver blocks
Puller
11-14-2002 22:56:17
It states in the Div. 3 rules that you must use stock engine or manufacturers replacement. Would a 195 gk block be considered a manufacturers replacement since no modification is needed at all to put engine into an 88. I guess that this is how I interpret the rule, what do you guys think? It says that you cant use any 7 main blocks, 99 heads, 12 port heads, and 1600 series heads but it does not say anything about using a 195 block. Would appreciate serious answers please. Thanks
Seamo
11-15-2002 06:37:58
 Re: Oliver blocks in reply to Puller, 11-14-2002 22:56:17
To clear up that rule I think they should list the block, manifold & head casting numbers that are ok to run on all brands of tractors.
