SUPER (M) SPINNING LEFT TIRE FIRST (PULLING)
BUD BARENIE
11-13-2002 16:40:01
NEED HELP TIGHTING UP THE REAR END ON MY SUPER (M) SEEM'S TO LOOSE TRACTION ON THE LEFT TIRE (FIRST)
AT TRACTOR PULLS !! CAN THE BULL PINION'S BE TIGHTENED UP, OR WHAT SHOULD I DO TO MAKE THE TRACTOR PULL EVENLY BETWEEN BOTH TIRES . RUNNING DIVISION (1) OR FARM FIELD!!! TRIED WEIGHTS AND TIRE PRESSURE !!! IS THEIR A TRICK UNDER THE TOP LID I CAN USE !!!
wastedtime
11-14-2002 17:54:10
 Re: SUPER (M) SPINNING LEFT TIRE FIRST (PULLING) in reply to BUD BARENIE, 11-13-2002 16:40:01
measure and see if both tires are equal distance from the end of the axle. One tire out further than the other will make one tire spin out faster.
hitch
11-14-2002 16:47:22
make sure your hitch is centered,, 100%
deadeye
11-14-2002 04:08:05
Let 2 lbs. of air out of the left rear tire and leave the right one as is.
randy hall
11-13-2002 21:05:59
in our div 4 m i got the positraction kit from the place in lima ohio that used to advertise in the hook, i don't remember the name of the place. in our div 2 m's we ride the brakes to keep one wheel from spinning.
BUD BARENIE
11-18-2002 06:53:03
 Re: Re: SUPER (M) SPINNING LEFT TIRE FIRST (PULLING) in reply to randy hall, 11-13-2002 21:05:59
I DIN'T NO THEIR WAS A TRACTION CONTROL KIT FOR A SUPER (M) HAVE ANY IDEA WHO THAT WAS IN LIMA .
THANK'S FOR ALL THE REPLIES !!!
Flyin Farmall
11-13-2002 17:53:21
I think you can shim up the diff side gears,I'm not sure though,I will know more in next couple monthe,after I change my gears.Anyone know for sure??
Trapper Jr
11-13-2002 17:08:42
I am not much on Ms But my oliver that I pull spins one tire one time and another tire the next.
What I just do is when a tire starts spining I just tap that break lightly and that causes the other tire to pull. just my two cents Trapper Jr
