JD G Manifold questions?
Jack
11-13-2002 14:50:10
Would a Jerry's manifold be a good choice on a stock stroke G with over size pistons(high compression)?The place where I had my manifold ordered from does not have any more left and it will be a while before he has any more.I wanted one that worked best with my set up.Where is the best place to find a propane manifold?If I thought it would be too big for mine than I would not use the Jerrys Manifold.Just seeking some straight up advice,thanks fellas.
Thanks G People
11-14-2002 09:40:25
 Re: JD G Manifold questions? in reply to Jack, 11-13-2002 14:50:10
N/T
burns
11-14-2002 06:08:48
Jack---Jerry has two manifolds. One with 2" intake port and one with a 2 3/8" port. I am currently running the 2" manifold and am very pleased. I did have the intake runner in my head milled the entire length to match the runner in the manifold, also.
Todd
11-14-2002 06:00:43
Detwiler tractor has the LP style manifold. detwilertractor.com By the way, thanks for the info on the G pistons.
JDBert
11-13-2002 17:16:34
Jack, try Roberts carb I got a manifold for my A there and I have this friend who got one for his G there. Pretty sure those are Jerrys manifolds.
Gman
11-13-2002 16:40:02
Jack I think Jerry will make the exh. manifold to fit stock head or the head that he produces give him a call(nice fellow)1-316-838-1908. garland
G-MAN
11-13-2002 15:35:43
Jack, I've heard that Triple G Service is the place to get the propane manifolds. I've also heard that the Jerry's manifolds have bigger ports and such than you really need for a stock displacement "G". I'm planning on going with a regular F1074R gasoline manifold on my "G". There are more knowledgeable people on this board than me, and they may have different ideas.
Jack
11-14-2002 09:38:27
 Re: Re: JD G Manifold questions? in reply to G-MAN, 11-13-2002 15:35:43
I talked with Bob and he is out and don't know when he will get any more.Thanks Gman.
