Someone to set a advance curve on a Delco dist.
Dave T.
11-11-2002 15:57:10
Does anybody know of a place that can set the advance curve to my engine specs? Besides Dennys Carb shop.
Thank You!!
Dave.
Dave T.
11-13-2002 19:57:59
 Re: Someone to set a advance curve on a Delco dist. in reply to Dave T., 11-11-2002 15:57:10
Thank you ALL for the advise. I will let you know how things work when I get the dist back from Motec. Matt really seams like he knows his stuff on the two cylider distributers.
Dave T.
kjm
11-12-2002 20:40:33
Dave, You just need to find a local shop that was in business back in the 1970s or before.It used to be about half the auto shops around had a Sun Dist Machine but nobody has used one since 1975. lol kjm
Matt at Motec. NT
11-11-2002 17:59:22
steve
11-11-2002 16:24:04
You will really need that advance curve with that huge rpm range you have.
makin fun of JD,Steve?
11-12-2002 07:19:40
 Re: Re: Someone to set a advance curve on a Delco dist. in reply to steve, 11-11-2002 16:24:04
I also pull a John Deere,(and proud of it)and I was wanting to know if there were some people who have dynoed John Deere tractors with the distributor worked on,and if there were any signifigant gains doing it?If it would get just one hp than I would get it done.Does it work on a low rpm engine?Later Steve
burns
11-13-2002 03:34:06
 Re: Re: Re: Someone to set a advance curve on a Delco dist. in reply to makin fun of JD,Steve?, 11-12-2002 07:19:40
Steve I don't have dyno numbers but I had noticed an improvement in the mid range performance on my G. I think Deere would set full advance on the distributors around 600 rpm. Any improvement done by recalibrating your distributor will help. Heck for around $30 you can't go wrong with Motec.
G-MAN
11-13-2002 07:54:44
 Re: Re: Re: Re: Someone to set a advance curve on a Delco dist. in reply to burns, 11-13-2002 03:34:06
Good point, Burns. It has nothing to do with whether the engine will run 975 rpm or 9750 rpm. It all comes down to getting all the performance out of it you can. That's what wins races, pulls and whatever else.
Slo
11-11-2002 16:13:39
Motec recurved the dist on my MM. Very happy with it.
765 963 6628
