JDA pulling tractor
phil
11-10-2002 19:11:03
wanting info on stroking an A to 10" and what all has to be done to get there. also not sure what bore i want to go with.also is there a big differance in heads { i have stock head right now) can i use it just work on it ? or should i look for differant on?
A-Team
11-15-2002 15:15:04
 Re: JDA pulling tractor in reply to phil, 11-10-2002 19:11:03
What year A do you have. The later models are harder to do. A 10 inch stroke would be very diffucult.Go with a 9 inch. It goes in with alot of gringing and cutting. It also is alot stronger crank then 10 would be.
dp
11-10-2002 20:10:49
you'll have to move your cam for the crank to clear.
11-12-2002 19:18:33
 Re: Re: JDA pulling tractor in reply to dp, 11-10-2002 20:10:49
what about the gear in the back behind the casting divider?
