Tachometer
greg
11-10-2002 13:39:08
does anyone know were i can by a tachometer for a john deere with a mag? thank you
G-MAN
11-11-2002 10:10:27
 Re: tachometer in reply to greg , 11-10-2002 13:39:08
What model of JD are you looking to install it on? Deere made kits to install a speed-hour meter that was driven off the RH end of the governor on several of the letter series tractors, and then they became more common on the number tractors on up. It consisted of a bracket, meter, governor shaft, end cover and so on. You might be able to find a used one or possibly a NOS set-up. You might also be able to find some kind of electronic tach with an inductive pick-up that will read off a plug wire.
