Weld on hub question
Don
11-03-2002 14:54:15
What's the big advantage of weld on hubs, that would make them illegal for div.2? I bought the tractor that way, and I think I would get my but kicked with only 60 HP.
WELDOW
11-03-2002 15:45:49
 Re: Weld on hub question in reply to Don, 11-03-2002 14:54:15
Well the first thing is,you have to find sombody that can WELD,when I was in Princton one year,I saw more broken weld on hubs ,then ever,at a pull.
IF welded right,weld on are alot stronger than reguler hubs,because,they don't loosen up.There lighter,too.IN some clubs you can't use WELD-ON'S because THEY don't know how good of a weld job that's been dun.Check with the Clubs you plan to pull with,as far as NATPA is concerned,DON'T GIVE THEN ENY IDEAS" Donny.
