Seamo carb update
howard
10-29-2002 03:51:48
just to let you know .I got my 48 jd A to pull well.18 tractors in the class and mustered out a first place pull to finish the year out on a great note. I put the right size full line on and made all the difference in the world on lug down thanks for the help howard.,
SEAMO
10-29-2002 10:07:00
 Re: seamo carb update in reply to howard, 10-29-2002 03:51:48
Howard, Happy to hear you finished your season on top. I see so many tractors that sputter and miss at the 150--200ft. Earl In Illinois
Mike in Mo
10-29-2002 19:21:37
 Re: Re: seamo carb update in reply to SEAMO, 10-29-2002 10:07:00
SEAMO I've got a question for you. I'm getting ready to put a fuel pump on a 2 banger DLTX71 carb. Any thoughts on float setting? It's a low pressure (5-7 psi) pump. My guess is to set it a little lower. I can put on a sight tube on it to check the actual fuel level. Thanks Mike
SEAMO
10-29-2002 19:45:42
 Re: Re: Re: seamo carb update in reply to Mike in Mo, 10-29-2002 19:21:37
Mike, You must have a hungry JD. I think it would be Ok. I have tried it but don't remember the fuel pressure setting. In Illinois we can't run fuel pumps in ITPA. WE make up larger needle and seat and get by OK.
