Natpa ? 4star MM = 445MM
slow mo57
10-28-2002 10:02:10
They run same engine, drive line & sheet metal.445 ran from 1956-58 4star same tractor new letters & grill 1959-63.If you check all same specs. expt.for rpms.they are the same tractor.To look from the side or the back you can not tell them apart.Is it legal to pull 4star next month in ohio in div 2.? I have a puller that would like to pull his 4star there.His tractor meets the rest of your specs. The smaller 445 changed to 4star to match the bigger 5star MM. Same ? for COATA.for march. thank you.
slow mo 57
10-28-2002 13:31:37
 Re: natpa ? 4star MM = 445MM in reply to slow mo57, 10-28-2002 10:02:10
I made a misstake they did run some 445mm in 1959 about 1/2 as many as they did run per year from 56-58.If you put 4star run from 1959 with 445 it comes out close to the same as earlyer years runs.
Moline Man
11-02-2002 00:46:00
 Re: Re: natpa ? 4star MM = 445MM in reply to slow mo 57, 10-28-2002 13:31:37
Yup, their the same tractor with just a slight grill change. Moline changed to the star series because the 5 star would have been called a 545 and another tractor was already using that # for their tractor.
FRIEND info on tractors in other post only took few min to find.
11-02-2002 13:14:08
 Re: Re: Re: natpa ? 4star MM = 445MM in reply to Moline Man, 11-02-2002 00:46:00
sorry 4star is out .From friend of slow mo
11-02-2002 12:44:45
NATPA ruled to new for any one wanting to bring one. It dont make a differts if D17 that started in 1958 if you look at AC sight seirial #s on top of this page. 730-830 JD ran after deadline also.
At lease 4 star ran same sheet metal and engine unlike JDs 730-830 verses 720--820!! MM PULLER
Slowmo57 to friend
11-03-2002 07:54:03
 Re: Re: Re: Re: natpa ? 4star MM = 445MM in reply to sorry 4star is out .From friend of slow mo, 11-02-2002 12:44:45
Hey pulling is about having fun.If you would like to come and have fun with rest of us you can pull 1 of my rides.I like to watch my tractor pulling just about as much as I like pulling it. Just give me a call if you would like to.
