Vac case tug puller
jason
10-15-2002 16:30:59
we are wanting to build a lite wt. tug pulling tractor,a lot of local pullers use the wc and wd45 tractors , there is as lot of h and m farmalls, we are wanting somthing different, any imput about a vac case would b helpful, we are wanting to get around 2500 lb or less, to give the gibsons and the averys some comp,is the 4 sp tranny in the vac to fast , we havent bought one yet ,but are thinking about one for a winter project, thanks
Augie
10-15-2002 21:18:49
 Re: vac case tug puller in reply to jason, 10-15-2002 16:30:59
It's cheap and easy to make a VACuum into a good pullin tractor.
I know how to do it. Shoot me a email...
CASEPOWER
10-15-2002 17:52:35
I am building a VAH/VAC for my son to pull in 2700 and 3000# class. There is a lot you can do depending on the rules. You can put in a old model 148 CID and take out the 124 CID engine or you can find a 201 out of a combine and put it in, but it is 2 inches longer. The late 148 engines are about 1" longer, but will fit. I know the late 148 and the 201 have a counter ballanced crank, but is heavier, I guess that depends on how many RPMs you want to turn. Case made 3 different size bull gears for the VAC a 65, 66, 67 tooth. Most are 66 and will pull fine, but if you want to pull the heavier classes find a 67 bull and some 12 tooth bull pinions. The heads are easy to work and you can take .125 off easy and still have enough meat if your cooling system is OK. The heads have 4 intake ports instead of 2 like most tractors so that is easy to work with if they let you get by with a home built manifold you can really make it flow. Small block chevy valves can be adapted real easy. Massey 22 9 bolt hubs will fit right on with no mods. There is a lot you can do and yes 2500# is easy to get two, but that won't leave much weight to play with and you will need some on the front.. Any questions e-mail me.. CASEPOWER
