Oliver 77 standard, ok for novice?
rhudson
10-11-2002 08:23:10
i have a 1950 77 standard. is it a likely candidate for a beginning puller. or is it too heavy?
Thanks
signed "do i really need another hobby?, hudson"
Dick
10-11-2002 14:28:18
 Re: oliver 77 standard, ok for novice? in reply to rhudson, 10-11-2002 08:23:10
Like anything else it depends how much time and money you want to put in it. Even a standard can be lightened up. If you decide to get alot of power out of the motor then I think a standard has the advantage of a higher gear ratio, so you can out pull rowcrop olivers in classes that limit you to first and second gear.
