Wiring 6A box
johndeere
10-09-2002 20:08:23
I have a 1951 G that I pull. I'm trying to figure out how to wire a MSD 6A box to it. It has an electronic ignition system from Denny's in it. Do I use the Petronix ignition system diagram to wire it up? Is a Petronix and Denny's the same kind of set-up? Where do a wire in my resistor? Thanks for the info.
MF95
10-10-2002 20:13:44
 Re: Wiring 6A box in reply to johndeere, 10-09-2002 20:08:23
Yes, you should wire it according to the pertronix diagram...Denny's electronic ignition is a pertronix...when you put on the MSD box, you no longer need the resistor....just follow the directions exactly and you should have no problems.
