Posi traction
joe
10-09-2002 16:59:47
I have a farmall m and see people advetizing for posi traction what do you think fact or fiction
Farmall Boy
10-10-2002 17:43:27
 Re: posi traction in reply to joe, 10-09-2002 16:59:47
I have saw it and called about it.
They have an add in the back of the hook book for
750 or 850$ and he does it by doin somthing to the
brakes.
Farmall Daddy
10-10-2002 12:46:47
Sounds to me like it is some form of traction booster system like they put on 560's.
Ed
10-10-2002 08:49:07
Could you tail me where you seen this poss traction add at. I would like more info??
Goldsburg
10-10-2002 06:48:54
Joe -
The "posi-traction" modification to these antique tractors is not a differential swap out. What "they" are selling is a kit that when installed will place a pre-determined level of binding in your existing differential. This moderate binding will force a small amount of bias to the "non-spinning" wheel. Often this is enough to keep the tractor moving if one wheel hits a loose spot. The level of bias (binding in the differential) can be changed depending on your personal preference. If the differential is too tight it can "lock" or make some pretty disturbing noises when turning.
The "kit" to modify your differential is most likely some type of washer, bronze flat bearing, and/or shim stock, depending on the model of tractor in which it will be installed. On some models of tractor this phenomenon can also be accomplished by removing shims from the bearing caps on the bull pinions, thus putting a little squeeze into the differential side gears. Be careful if trying this for the first time, as it is very easy to remove too many shims and "lock" the rearend!
Regards,
Goldsburg
[email protected]
Flyin Farmall
10-09-2002 18:18:44
Where did you see this??What is involved,a complete locker unit or what?let me know.
m
10-09-2002 17:56:18
fact
Michael Earnest
10-09-2002 19:48:42
 Re: Re: posi traction in reply to m, 10-09-2002 17:56:18
Will it work on a 560?
