More power
jim
05-31-2001 20:51:37
How can i get more power out of my farmall-A without boring it out.Would like little more power to pull plow and run belly mower Thanks very much for your reply
pauldeere
06-02-2001 08:39:39
 Re: more power in reply to jim, 05-31-2001 20:51:37
I agree with the other post, an "A" dosn't give you mush to work with, however slight gains can be acheived by a good tune up. By this I mean good accurate carb. settings, fresh plugs, plug wires, point gap setting, correct timming. All of these things can give a noticeable boost in performance. Remember an engine is just like a pump, it sucks gas and air in, combusts it, and blows it out, anything you can do to improve this process is a gain in power. A lot of gain can be had by haveing a reputable machine shop rebuilding the head. Accurately ground valves, valve springs with the correct tension, new valve guides, and new valve seals, should add a few more ponies to the ol' "A".....
Johnny
06-01-2001 21:14:23
These little A's don't have much horsepower. They were intended for one row farming and cultivating. Even resleaving it with the increased bore isn't going to do much for a gain in hp. If you want more power trade it in on something bigger. I don't even know why I.H. would put a pto on these little tractors a 4 ft. mower is almost too much for it. Should pull a belly mower fine as long as the grass don't get too tall. Great little garden tractors though. What gear are you running in? Johnny
jim
06-02-2001 20:23:50
 Re: Re: more power in reply to Johnny, 06-01-2001 21:14:23
I heard that a 300 or 504 camshaft would interchange in the A-farmall but don't know what i would gain if anything.I thank you for any information you may have to offer.
