Tunica,miss pull,classes rules
reddog
10-07-2002 04:03:06
Why wont they post them? mean green or usap, something smells,think ill not drive 14 hours
Wide Front SM Puller
10-07-2002 11:15:21
 Re: tunica,miss pull,classes rules in reply to reddog, 10-07-2002 04:03:06
I meant "better" version, must of had a brain freeze.
10-07-2002 11:14:19
Send me your e-mail for a berrtrt version in a Word document.
10-07-2002 04:38:28
How does this smell? Nothing to hide, I had an earlier post saying to anyone who needs the rules can send me their address and they will get them. If you think you can compete with some great competition and put up with some great facilities and hospitality we would love to have you here.
Let me know if you can make it.
Southern Nationals Rules Tunica Mean Green Pulling Team December 6th and 7th
FARM STOCK II CLASSES: Pre-1960 Tractors with stock engine No cut tires 18.4 x 38 MAX Hang on Weights-ok 10% over stock RPM
Wheelie bars are mandatory 1st gear only, 4 mpg max 4MPH, 8 MPH CLASSES: Pre-1960 tractors with internal engine mods Spacer Plates, girdles, power blocks 12 port head, 800 heads & jugs ok All parts must be of tractor origin 18.4 x 38 max tire, any cut, any rim width no duals Weights: 11" from center of rear axle to furthest point of front weights Rear weights must not stick out past tires on rear 20% over stock RPM Any gear, 4.0 MPH MAX 8.0 MPH MAX Draw bar 20"High, 18"back from rear axle Wheelie bars & breakaway switches mandatory No alcohol, no nitrous, no turbos, no blowers NO SPEED LIMIT Same as above Except 30% over stock RPM
Speed limits start when any part of tractor passes the orange cone at 1/2 track. Tractors with side shields may be inspected. If a protest is made, it must be made before the end of the class. Protesters tractor will be examined first.
Then and only then will the protested tractor be checked.
Only a total of 3 pulls for 2 days
This is the pull order for both days:
Friday Saturday
Farm stock II Modified Modified Modified
Green Sled White Sled Green Sled White Sled 4500# 4mph 6200# NoLMT JD KOH All Oth KOH
5500# 4mph 7200# NoLMT 3500# 4mph 6500# 8mph
6500# 4mph 7500# 4mph 3500# 8mph 6500# 4mph
7500# 4mph 7500# 8mph 4200#NOLMT 5500#NOLMT 10000# 4mph 4500# 4mph 4200#NOLMT 4500# 8mph 5500# 8mph KOH-King of the Hill
NOLMT_No Limit
*Remember: This is a hobby for fun. It's not a political debate or event
