Wheel width vs. tire width
Jim B
10-01-2002 05:22:13
Can a 14.9 tire be run on an 11 in.rim sucessfully?Thanks,Jim B
Seamo
10-01-2002 20:40:46
 Re: wheel width vs. tire width in reply to Jim B, 10-01-2002 05:22:13
Can someone explain to me how a rim wider than the tread will give you any advantage.I have talked to the tire manufactures and they just laugh. They have spent a ton of money on reasearch on rim width and tire pressure.I just witnessed a pull at Paris ,Illinois Sunday the man that won the most had 15.5 on 14in. rims.The wide rims weigh more and are more flexible if you don't get the centers in the middle of the rim. Just my 2 cents .Have fun!! Earl
horsepower??
10-03-2002 17:10:34
 Re: Re: wheel width vs. tire width in reply to Seamo, 10-01-2002 20:40:46
that guy also can run around 10 mph at that speed what diff does the rim make ?????!!!
SEAMO
10-03-2002 18:47:18
 Re: Re: Re: wheel width vs. tire width in reply to horsepower??, 10-03-2002 17:10:34
Lets watch and see if he takes them off!!!!!He sure wasn't going 10mph at the end.
52 A Boy
10-01-2002 14:28:54
I have 14.9's on a 11 in. rim and they do fine I have never had a problem and always get a good footprint on the ground.
52 A Boy
Ted
10-01-2002 09:19:38
I just put my 14.9 F&R on 14" rims.They still crown some.In my opinion 11" is way to narrow.
mguy
10-01-2002 07:38:25
I pull 11" on my 14.9 and they work great never had a problem always get a good bite. them 14.9 do better on a litle rim
chad
10-01-2002 05:45:07
I would'nt do it. I have 12.4's on 11" wheels and want to build some 13's. The wider the wheel the more tire on the ground. Hope this helps you out. chad
