Wc allis puller
dale t
09-26-2002 20:59:17
A friend of mine is building a wc allis puller. I found in the grove a leroi 226 engine. I took the head and manifold off it and noticed that the head had a combustion chamber in it. Is this head any good? I,m under the impression that the allis head is flat? What rods and pistons do you need to stroke the engine 1/2 inch. Any other tips would be appreciated.
Thank you
bigmotors
09-28-2002 06:25:08
 Re: wc allis puller in reply to dale t, 09-26-2002 20:59:17
With 4 9/16 flat tops pistons, about 12 to 1.
265 cyl. pressure.
Bob
Allis Puller
09-29-2002 19:11:42
 Re: Re: wc allis puller in reply to bigmotors, 09-28-2002 06:25:08
Tell me exactly where do you find a block to fit 4-9/16" pistons? That roughly .560 over stock, do you know someone thats done this? I've had one 1/4" over but thats pretty far from 9/16.
bigmotors
09-30-2002 02:41:11
 Re: Re: Re: wc allis puller in reply to Allis Puller, 09-29-2002 19:11:42
4.5625 is old news anymore, there's alot of 4 5/8 out now. Yes, I know of four for sure at 4 9/16. And they have been running along time at that. Your sleeves run right around .105 thickness, in a WD block. At 4.625 and bigger, you should weld the sleeves in. I know two people right now going to try 4.750! About the time you think that's the limit, someone goes bigger. I also know of two 6 1/2 inch cranks. There not in the tractors yet. I'll put it this way- you could buy them really cheap about now!
bigmotors
09-27-2002 12:47:49
The Leroi has two heads, check your head gasket - it should work. The cam out of a Leroi works good too. Find some big block chevy pistons 4.250, and off set the wd-45 crank a .250 inch. It's a cheap set up, and runs good for small wt. classes.
Good Luck!
AC190
09-27-2002 09:00:15
WD-45 crank and 175 pistons and head.
dale t
09-27-2002 07:16:35
Would the leroi engine have the same crank that the wd-45 uses? It appears to be 4.5 stroke. The manifold of the leroi looks almost like a header and the carb is a zenith and is bigger also. is there any of these parts that could be used?
John
09-27-2002 06:23:28
Popular belief is a wd45 crank and D-17 pistons..... .....thi would work if you want a D-17 engine. Granted this will be quite a wake up for the little WC however I assume you want a semi-nasty pulling motor. You still will use the time honored WD-45 crank but use WD/WC pistons. The compression height of these is greater due to the reduced stroke the stoke engines have. Depending on the exact piston you use, the compression ratio is around 10:1. This will require high-octane fuel and attention should be paid to ignition timing. I have used the smaller WD/WC carb but removed the load screw to flow more fuel. A WD45 carb or a carb off a Gleaner 6-cylinder will really flow, but may require intake flange work. Keeping the fuel cool helps so if possible use a WD-45 Y manifold. If you have the time and patients, bowl blending and a mild or crazy deburring of the heads will help. Any competent machnie shop can install larger chevy valves. Anyway, I think you would enjoy the WD piston/WD45 crank combo.
Allis Puller
09-27-2002 20:07:37
 Re: Re: wc allis puller in reply to John, 09-27-2002 06:23:28
Hey John what kind of compression per cylinder are you getting with that combo? Just wondering, I don't know anyone that's done it to talk to them.
John
09-30-2002 05:49:23
 Re: Re: Re: wc allis puller in reply to Allis Puller, 09-27-2002 20:07:37
It will depend on your camshaft profile and how you install it, that is straight up or advanced. Providing everything else is in good shape cranking pressure around 200 psi.
Tom W
09-27-2002 20:06:49
John, What head did you use with the WD piston and WD45 crank setup? What about valve clearance?
mike b
09-27-2002 04:15:41
use a 45 crank & D-17 pistons
