Electronic Ignition
Toot
09-13-2002 11:10:45
A friend of mine is letting me use a JD delco distributor converted to electronic by no other than DENNY. Has has one of the two wires marked to go to the - side of the coil. Where does the other wire hook up at? Nice answers please.
DCPULLER
09-15-2002 15:55:11
 Re: Electronic Ignition in reply to Toot, 09-13-2002 11:10:45
Don't forget the resistor you need.
burns
09-16-2002 03:41:06
 Re: Re: Electronic Ignition in reply to DCPULLER, 09-15-2002 15:55:11
That is dependent on what type of coil is being used. Borg Warner makes a coil with the internal resistor as does Pertronix's Flamethrower coil. Good thing to check
G Taylor
09-16-2002 09:49:33
 Re: Re: Re: Electronic Ignition in reply to burns, 09-16-2002 03:41:06
I wonder which type of electronic ignition? Some have variable length dwell depending on the rpm to eliminate the need for a resistor.
LeeJon
09-14-2002 09:54:48
Where is your friend????? ? Ask him.
burns
09-13-2002 12:07:48
First be sure you are running a negative ground 12v system. There are some 6v units but most likely it is for 12v system.
Second the red wire attaches to the (+) post on the coil along with the wire coming from the switch. The black wire attaches to the (-) post on the coil.
If you have access to a dyno, you can dial the sweet spot of the distributor to gain peak HP.
Good luck
Nice enough for ya?
Doug in OR
09-13-2002 19:57:26
 Re: Re: Electronic Ignition in reply to burns, 09-13-2002 12:07:48
And be darned sure you bring the ignition (hot) wire to the + side also... anything else will blow the ignition sensor.
toot
09-13-2002 13:29:23
very nice. thanks
