JD 70 Powerblock?
Todd
09-11-2002 19:31:51
Is there such an animal for a 70 Gas?
Keith
09-17-2002 17:12:25
 Re: JD 70 Powerblock? in reply to Todd, 09-11-2002 19:31:51
I have one Bored to 7.25" for sale
563-582-8710
Eric
09-12-2002 05:12:32
Yes. The original 70 gas "power block" was built by TSC. It will have 7-2 raised cast numbers on the top of the block. The 7-1 power block is for G's and 70 all fuels. Now there are folks casting new blocks for the pullers with 7.5" bores (as mentioned by BushhogPapa).
The expert on the original TSC power blocks is WTW. He has explained them in detail in previous post. Try doing a search on WTW.
BushogPapa
09-11-2002 19:45:17
The Gas 70 has a 5.875" bore..... The All-Fuel 70 has a bore of 6.125".....
This give you any ideas???..!! There surely some after-market 7.5" bore blocks out there, if you have the $$$$$$$....
JDGnut
09-11-2002 19:58:41
 Re: Re: JD 70 Powerblock? in reply to BushogPapa, 09-11-2002 19:45:17
U better check out that set up first..
